Discussion topic: No signal whilst roaming
Message posted on 27 Jul 2024 07:10 PM
Message posted on 27 Jul 2024 07:19 PM
Re: No signal whilst roaming
Is your phone's status set to abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
Message posted on 27 Jul 2024 10:58 PM
Hi Caesarome,
It wasn't set to abroad so I have done that and restarted the phone but I still can't get a roaming signal, AT&T pops up for a brief moment then it goes back to emergency calls.
Message posted on 28 Jul 2024 02:29 AM
Whereabouts are you roaming?
I'm currently in Florida and working fine with AT&T. Have you set a spend cap?
Message posted on 28 Jul 2024 04:03 AM
I'm in Pennsylvania, no spending cap. I have never had this issue before with phones just this new Motorola. I'm wondering if my original settings were incorrect as reading on the internet I need VoLTE and this doesn't appear as an option anywhere.
Message posted on 28 Jul 2024 09:34 AM
Have you tried setting a spend cap ?
According to this article if you are running Andriod 12 or above thenyou phone should have VoLTE.
Message posted on 28 Jul 2024 08:32 PM
I think I have the VoLTE thing sorted although it doesn't actually say VoLTE and I have tried manually selecting a network but it won't connect.
I have also tried configuring the APN but I still can't get a connection.
