Discussion topic: No signal in Lanzarote
Message posted on 17 Sep 2024 05:11 PM
Arrived in Lanzarote on Sunday, have no signal whatsoever. Tried every 'fix' suggested. It's vital I have contact with the UK. Please can anyone tell me how to sort this?!!
Message posted on 17 Sep 2024 05:26 PM - last edited: 17 Sep 2024 05:26 PM
Re: No signal in Lanzarote
@Ann1968 wrote:Tried every 'fix' suggested
It's hard to advise if we don't actually know what's been tried and what phone it is.
But it's possible it just won't work - others have reported issues connecting. (There is no contractual guarantees it will work)
However, ensure you have a spend cap set. Try manually selecting networks. Ensure roaming is on and SIM application setting is not set to 'home'.
Message posted on 17 Sep 2024 05:28 PM
I've got a Samsung S22, never had issues abroad before. No spend cap and won't manually connect to networks
Message posted on 17 Sep 2024 05:32 PM
@Ann1968 wrote:I've got a Samsung S22, never had issues abroad before. No spend cap and won't manually connect to networks
Ensure:
Sky Menu App or SIM toolkit > Roaming > Make sure this is NOT set to Home.
Although no spendcap should be fine, try setting one sufficiently large.
Message posted on 17 Sep 2024 05:33 PM
It's set to abroad.... tried putting in a sufficient spend cap.... nothing works 😢
Message posted on 25 Oct 2024 09:31 PM
Hello there
Just arrived in Lanzarote. Me n mrs both woth sky mobile. Never had any issues abroad Both got no network other than WiFi. Did you resolve your problems?
