22
This discussion topic is read only This discussion topic has been answered Discussion topic: No signal and no mobile data abroad in Spain
This message was authored by: Aiden9
Hi I'm currently in Tenerife and I have no signal and no data so can't text or use phone help me fix this
Moderator note: Edited title for clarity.
This message was authored by: Samraj Answer
Re: No signal and no mobile data abroad in Spain
Posted by a Sky employee
Hi, everyone!
Based on the lack of feedback received following my last post, I've decided to lock this discussion.
For anyone experiencing similar issues, please follow troubleshooting steps (see post 22) before creating a new discussion.
Thanks 👍🏽
Samraj
Sky Community
Community Manager
Locked
Start here: https://www.sky.com/help/articles/sky-mobile-roaming-problems
This message was authored by: EJHubs07
Data roaming won't work in Menorca
I we have just landed in menorca on holiday and my data roaming is not working. No welcome message, no phone signal, messaging or mobile data. I have tried all of the suggestions on the sky help and am out of ideas. It's worked on this phone for previous trips and my husbands and daughters phones have kicked in as normal. Any suggestions would be very much welcome?
Re: Data roaming won't work
Hi @EJHubs07  there has been quite a few reports of roaming issues lately. Have you tried turning off automatic network selection then try a manual search and connect to others that appear ? If it's an iPhone try settings, mobile service, sim applications and change the setting there ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Hi yes I have tried that, it won't let me access any of the networks as it says my sim does not allow access to them which is strange as they worked perfectly fine last October.
I have a samsung galaxy phone
Although you don't have to have you tried setting a spend cap ?
Yes its already got one on it
This message was authored by: Jake77
My data roaming isnt working
My data roaming isn't working in tenerife
Re: My data roaming isnt working
@Jake77
You could try turning off automatic network selection in the settings then get your phone to search for other available networks to see if it will then connect and allow you to make calls. Also make sure the spend cap hasn't been reached if you have one set.
Although you don't have to, do you have a spend cap set because if you do it needs to be high enough to cover your stay.
This message was authored by: Pottig
Roaming: No network and "refreshing SIM data"
Hi,
I am currently in Spain and am struggling to get any network coverage out here. I either get "Emergency calls only" or "No service" in the status bar and the "Refreshing SIM data" popping up every few seconds.
I have looked at all of the solutions on here and elsewhere and nothing is working.
I have rebooted my phone, turned airplane mode on/off, requested network settings in the My Sky app (but I don't receive any notification), and gone into Sky Menu and pressed "Automatic" etc. in there.
I have also attempted to create a new APN manually, however when I create one and enter MCC 234 and MNC 57 and press "save" the APN I created just disappears.
Please, does anyone have any other solutions to this problem? Thanks very much.
Re: Roaming: No network and "refreshing SIM data"
@Pottig
As well as automatic due you also have the option for abroad ?
This message was authored by: Ben204
No sevices in menorca
Been in menorca 6 days and my data roaming has been fine. Now I have no service at all. Airplane mode is off. Data roaming is off. Turned my phone on and off. Now I have no service or data??
Re: No sevices in menorca
Sorry my data roaming is on
Hi @Ben204  this does seem to happen with roaming in Spain quite often. Have you checked you haven't reached either of your two spend caps ? Also try turning off automatic network selection in your phone settings then select different networks from the list.
This message was authored by: Puredublin
Appalling no sky mobile coverage in spain
Cannot get into work emails or mobile banking here in San sebastian because of no mobile cover ,what a disturbing from sky mobile
Locked
Answered - Go to Answer
