3
This discussion topic has been answered Discussion topic: No signal abroad
This message was authored by: Kilbanesteve
No signal abroad
iPhone 13. Won't find a network when I'm in France. When I landed I got warned about a charge for using my mobile phone abroad , via a text message, but the the signal disappeared and I can't make calls, receive calls or messages. I've tried all the guides and my  roaming  is switched on
steve
Re: No signal abroad
@Kilbanesteve
Do you have a spend cap set and if it high enough to cover your stay, have you tried seeing if your device will connect to a different mobile network ?
@Kilbanesteve
Avatar for Kilbanesteve
Thank you. Thought I had tried all the suggestions but I've turned off the monthly spend cap and it's fixed means I'm spending more than I want though.... 😑
Hi @Kilbanesteve  in France you should only be spending £2 per day to access your home allowance. Extra charges will be incurred if calling local numbers as they aren't covered by the daily charge.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
