Discussion topic: No connection to network in Barbados
This message was authored by: Skiman
Looks like I can't connect to either Flow or Digicell in barbados. So can't check my VMs or make calls if I need to. Any suggestions pls
Re: No connection to network in Barbados
@Skiman
Hopefully you're aware of the very expensive costs as it's a Rest Of The World destination. The following charges will apply:
£2,160 per GB
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
Avatar for Skiman
Hi yes 😆 extortionate. I have an esim in another phone and tether for Data but can't even check my VM. So I don't know if I have had any important calls while away.
Avatar for Skiman
Managed to phone my vm from another phone.
Avatar for Skiman
Other than a bunch of silly badges. Is there any questions that get answered here?
