Discussion topic: No calls texts or roaming abroad
This message was authored by Leigh9 This message was authored by: Leigh9
Hi, I have came on holiday to Aruba, and when I landed I didn't receive a welcome text and I've still no data, calls or texts. My sister phoned sky they said it was to do with a spend cap which I knew was rubbish as I was aboard last month and it worked fine, my husband is also with sky mobile and has the same issues.
Re: No calls texts or roaming abroad
You do need a spendcap set so it needs to be set for the number of days you will be away multipled by the daily charge.
Leigh9
The spend cap was set 2 days ago by my sister phoning sky and our phones still aren't working. We have no way to phone sky ourself either as we only have wifi
This message was authored by 63johnw This message was authored by: 63johnw
Hi @Leigh9  have you tried searching for and connecting to a different local network ?
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
