Discussion topic: My phone will not connect to a network in lanzarote emergency calls only
This message was authored by: Debby5
Message posted on 30 Jun 2024 03:15 PM
I am in lanzarote phone won't connect to network so unable to use phone unless I come to WiFi can't text call or use my data done all the trouble shooting recommend on mysky
Find out more
Message posted on 30 Jun 2024 04:10 PM
Re: My phone will not connect to a network in lanzarote emergency calls only
If you have done all the trouble shooting then I'm afraid there isn't much more you can do as you are at the mercy of the local networks out there.
This message was authored by: Nigelb1972
Message posted on 30 Jun 2024 09:06 PM
Have you enabled roaming through your phone settings? By default, it's turned off
