Discussion topic: My phone isn’t charging
This message was authored by MillieDavey This message was authored by: MillieDavey
My phone isn't charging it only seems to charge on a wireless charger .
what should I do?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: My phone isn’t charging
what should I do?
Assuming the charger and lead is ok (try others) then it's usually the port itself.
You haven't said anything about the type of phone and age.
I am just another Sky customer and my views are my own
This message was authored by 63johnw This message was authored by: 63johnw
Hi @MillieDavey  check the charging port in the phone for fluff.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
