Discussion topic: My mobile is not receiving landline calls
This message was authored by: LLK
Been waiting on gp phoning but turns out it is not connecting to my mobile. I have tried from my work landline and its the same issue
Re: My mobile is not receiving landline calls
Hi @LLK  call sky on 150 so they can investigate.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
@LLK
Do you have Wi-Fi calling turned on if so does it work if you turn it off ?
Avatar for LLK
Yeah my wifi calling is always on, will try without it
Avatar for LLK
Doesnt work either with wifi calling off, and is saying number not recognised
It was worth a try so as @63johnw has suggested as you can make calls then call Sky on 150 so they can investigate it for you,
