Discussion topic: Is it possible to make anonymous calls on Sky Mobile?
This message was authored by JoSo This message was authored by: JoSo
I notice that it's not possible to make calls from my Sky Mobile phone by applying the prefix 141 to the number. Every time I hear an error: "Sorry this number doesn't exist." I did come across a post elsewhere dated 2019 that suggested using #31# as a prefix instead because Sky didn't support 141, but that results in the same error.
Fear not, I'm not a scammer or a stalker, but I have had to change my number several times when it's been leaked either deliberately or inadvertently by companies, so I'm apprehensive about supplying my number these days. And if I have to call, I prefer to obscure my number to prevent data harvesting.
Is there no way to make an anonymous call using Sky Mobile?
This message was authored by 63johnw This message was authored by: 63johnw
Re: Is it possible to make anonymous calls on Sky Mobile?
Hi @JoSo  just tried 141 then number on my sky mobile and it worked and withheld the number.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
JoSo
Hi @63johnw ,
The plot thickens. It seems I can call other Sky Mobile numbers applying the 141 prefix, but no 0800 / 0300 numbers etc. When you tried it, were you calling another Sky number?
Thanks.
Sky landline @JoSo
JoSo
@63johnw That's interesting. It seems I can also dial a 01865 number applying the prefix, but most of the numbers I've tried don't go through. It's odd that some numbers go through while others don't. Could it be a routing/config issue? (That may be a rhetorical question...)
This message was authored by Pabs101 This message was authored by: Pabs101
@JoSo Did you ever get a resolution to this? I too require to disguise my number to make work calls from my personal device but people are calling me back even though I put in 141 beforehand.
Ive recently moved from Vodafone to Sky mobile and I believe all worked well with Vodafone.
any help would be most appreciated
