Discussion topic: Iphone 17 pro max order was cancelled
Message posted on 22 Oct 2025 09:31 AM
Hi! I received a msg today cancelling my order of iphone pro max 17. I did not do this. Any reason it was cancelled?
Message posted on 22 Oct 2025 09:32 AM
Re: Iphone 17 pro max order was cancelled
Could be that the credit check was not successful - you'd need to contact Sky to confirm.
Message posted on 22 Oct 2025 09:34 AM
@Khaye
It’s possible you may have failed one of the required credit check(s). For a sim deal it’s just a soft credit check, for a device there’s also an enhanced check. Any emails which confirm or cancel the order sometimes arrive out of sequence. See this link for Skys guidance ~
https://www.sky.com/help/articles/credit-checks-sky-mobile
Be aware that if you keep trying to order the device this could further impact your credit score. If you contact Sky they would be able to confirm that’s the reason your order was cancelled but not why you failed the credit check in the first place as they are not allowed to view your credit record. You would have to sign up to a credit reference agency like Experian or Equifax, which would give you access to your credit record.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to contact Sky to chase it up.
Message posted on 22 Oct 2025 08:44 PM
Rang them today it was due to technical issues. They said this happens at times when people order it online. They re ordered the item for me.
