Discussion topic: International roaming in Corfu
Message posted on 08 Jul 2025 07:44 PM
Message posted on 08 Jul 2025 07:49 PM
Re: International roaming in Corfu
They didn't. It's a common mistake to pick up an Albanian mast if near the border. Sky aren't likely to reimburse you. See this link, in particular'accidental roaming' near the bottom...
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Message posted on 08 Jul 2025 07:51 PM
Sky has no say in how networks outside of the UK work but when you are near a border your device could connect to one in the other country as per this:
https://www.sky.com/help/articles/sky-mobile-roaming-problems-accidental-roaming
Message posted on 08 Jul 2025 09:23 PM
@Craig01_ wrote:
Why did Sky choose the network from Albania?
Sky didn't - your phone did.
I recommend not using automatic network selection if you are near Albania.
Message posted on 08 Jul 2025 09:27 PM - last edited: 08 Jul 2025 09:36 PM
Greece and Albania are a few kilometres apart at the narrowest point of the Straits. Unfortunately cellular signal isn't noted for its ability to recognise and then stop at an international border.
Message posted on 08 Jul 2025 09:39 PM - last edited: 08 Jul 2025 09:52 PM
Somebody at Sky should probably amend that article, because Turkey (despite not being in the EU) is a £2 per day destination.
Message posted on 09 Jul 2025 04:42 PM
Might be the phone being on auto select for network but can't help feeling that the situation is to Sky's advantage. Day 1 recognized as being investigated Greece = £2. Day 2 & 3 suddenly no more Greece but Albania & cost = £45
I wonder what Sky's margin is on that!!
Message posted on 09 Jul 2025 04:55 PM
@Craig01_ wrote:Might be the phone being on auto select for network but can't help feeling that the situation is to Sky's advantage.
True but Sky still didn't select the local network, your phone did...
