4
This discussion topic has been answered Discussion topic: IS SKY MOBILE DOWN ?
This message was authored by: Nails2767
I have only had "Emergency Calls Only" now on my phone for 3 days and trying to get hold if Sky us like getting blood from a stone, anyone else having this problem ?
Re: IS SKY MOBILE DOWN ?
@Nails2767
If there are no mast issues then you might want to get in touch with Sky to ask them to send you a replacement sim incase the one you have has developed a fault.
@Nails2767
Any relevant information showing on this link?
https://www.sky.com/help/articles/service-status-sky-mobile
@Nails2767
Avatar for Nails2767
I finally managed to get through to them, you are correct, its a faulty sim card.  thanks very much
This message was authored by: 40spring
I have had the same message - emergency calls only. I have done the following:
Switched to airplane mode  and then on/off.
Reseated sim - completely removing and replacing.
Check all sim info on mobile up to date.
Check coverage info with network.
