Discussion topic: I received a notification from sky saying i had to configure settings and to install about 6 things
This message was authored by Sugun59 This message was authored by: Sugun59
The notification from sky saying I needed to install some configuration settings has disappeared and its not in the history
Also I've been told that I would need to use roaming while I am visiting Ireland from the UK is that correct as I thought EU countries were the same as if you were in uk ?
Re: I received a notification from sky saying i had to configure settings and to install about 6 thi
You can get these sending sent to your phone yourself from here so this should be what you need to do:
Go to sky.com/networksettings (My Account > Mobile > Settings) and sign in with your Sky iD.
Select the mobile number or SIM name you're having trouble with.
Scroll to 'Resend network settings' and select Request settings.
Save the settings when your receive them and reboot your phone.
