2
This discussion topic has been answered Discussion topic: How to get roaming on my phone for 7days in Austria
This message was authored by: Barbie7
How to use my phone while in Austria.
This message was authored by: daveNOS Answer
Re: How to get roaming on my phone for 7days in Austria
@Barbie7 Roaming should be automatically activated when you use the phone for either data or calls/texts.
You will need to make sure you have a sufficient spend cap set(it costs £2 per 24 hours) and there is a cap of 25GB per billing cycle after which each GB is charged at £2.50.
@Barbie7
This link is Skys advice on Roaming via Passport Plus
https://www.sky.com/help/articles/sky-mobile-roaming-passport-plus
In addition Roaming using Roaming Passport Plus is now limited to 25GB per billing period.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel.
We may suspend your service, restrict your usage, or charge you for the data that you use in excess of these amounts (currently £2.50 per GB), and we'll let you know by SMS or email before we do so.
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy
