4
This discussion topic has been answered Discussion topic: How to connect to internet when sky mobile won’t connect
This message was authored by: tootman1
How to connect to internet when my sky mobile won’t work inside venue due to large amount of users ?
Re: How to connect to internet when sky mobile won’t connect
In that case unless there is Wifi available instead then I'm not sure what more you can do.
@tootman1
Your post isn't very clear, why isn't mobile data working ?
Avatar for tootman1
Thanks for your reply inside the stadium shows 4G on my Sky mobile But due to amount of people usage unable to connect is their another way to get on line
5G should suffer less from congestion if that's available.
You used to be able to drop down to 3G but they are in the process of switching that off...
