Discussion topic: How do I set my APN for abroad?
This message was authored by AnnieL17 This message was authored by: AnnieL17
Having not been able to use my Sky mobile abroad in March, I contacted Sky before travel last week. Set Spend cap. Assured all ok.
No Mobile data all weekend.  Roaming on; mobile data on. Searched APN - found not set for abroad.  How do I resolve this?
BT have a site which takes you through the process clearly and concisely. Am I correct in assuming that relates to BT connections?
@anneil
Re: How do I set my APN for abroad?
Depending on what device you have:
Apple:
Settings > Mobile Data > SIM Applications > Change to Home
Android:
Sky Menu App or SIM toolkit > Roaming > Change to Home
AnnieL17
Thank you, but that is not what the issue is.
@AnnieL
Sorry @AnnieL17 I meant to say those settings need to be changed to abroad if it is not set at this.
AnnieL17
Yes, Caesarome, I did that. I'm now going to try to speak to Sky.
