Discussion topic: Everyone abroad can't use mobike data and have emergency calls only. Have tried changing network to
This message was authored by: UserROI
Everytime abroad can't use mobile data and only get emergency calls. As you can never get speaking to someone directly their virtual assistant doesn't give any help. Has anyone else had this problem with Sky mobile and can you offer any help?
Re: Everyone abroad can't use mobike data and have emergency calls only. Have tried changing network
Are the phones set to abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
Although you don't have to, if you have a spend cap set is it high enough to cover your stay where you are ?
Avatar for UserROI
Thank you for the reply but I can't locate this option
What phone are you using @UserROI  ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for UserROI
Samsung S23
Do you not have a Sky app installed ?
Avatar for UserROI
I have MySky app?
Usually on a device such as yours you would have one called either Sky Menu or SIM toolkit so do yu have either of these ?
