Discussion topic: Esim not working with I phone 16
This message was authored by AnnieA77 This message was authored by: AnnieA77
Hi all,
I got an I phone 16 at the weekend and converted to an eSIM. I've scanned the bar code on the new phone and entered the emailed pin but it says unable to activate eSIM.
I have no phone service or calls and I'm desperate for my phone for work.
spoken to sky twice via my sons phone but they keep fobbing me off saying it's an known issue and it will be fixed by this evening (This was Monday and Tuesday)
Any ideas before I switch providers after 22 years of being with sky.
AnnieA77
Re: Esim not working with I phone 16
Have you activated the physical sim, if you have then you can  either use the physical sim as you do not need to use an eSIM but if you do want to do this then it might be worth insisting that Sky sends you another sim to try to convert which will mean cancelling this one.
AnnieA77
Thank you for your response. The physical sim from my I phone 13 doesn't fit the I iPhone 16.
I have just done what you've said and ordered a new one. Do you know how long it will take? I can't work without being able to receive/make calls or text messages- everything is linked to my phone as a 2-factor authentication 🙈
This message was authored by 63johnw This message was authored by: 63johnw
Hi @AnnieA77  the physical sim will fit, it should push out to the correct size.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
AnnieA77
Hi John,
it does fit - my apologies.
however it doesn't work anymore as it converted to an eSIM
AnnieA77
Can I reactivate my old physical sim?
Did you cancel it ?
AnnieA77
No it was changed to an eSIM for the new phone on the sky app.
my old phone (13 with the physical sim) stopped working (texts and calls)
and the eSIM wouldn't work in the new one.
Hence no calls/texts and no way of talking to sky as I don't have a land line
If it was converted to an eSIM then I don't believe it can be reactivated.
Hi @AnnieA77  i have escalated your post to sky so look out for a coloured speech bubble on here inviting you to a private chat.
AnnieA77
Thank you
This message was authored by Greenfingers001 This message was authored by: Greenfingers001
Posted by a Sky employee
Thanks for escalating this. We’ve sent @AnnieA77 an invite to chat.
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
We are still looking to help you AnnieA77 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
