Discussion topic: Esim not working with I phone 16
Message posted on 25 Sep 2024 10:54 AM
Hi all,
I got an I phone 16 at the weekend and converted to an eSIM. I've scanned the bar code on the new phone and entered the emailed pin but it says unable to activate eSIM.
I have no phone service or calls and I'm desperate for my phone for work.
spoken to sky twice via my sons phone but they keep fobbing me off saying it's an known issue and it will be fixed by this evening (This was Monday and Tuesday)
Any ideas before I switch providers after 22 years of being with sky.
Message posted on 25 Sep 2024 10:55 AM
Re: Esim not working with I phone 16
Message posted on 25 Sep 2024 01:19 PM
Have you activated the physical sim, if you have then you can either use the physical sim as you do not need to use an eSIM but if you do want to do this then it might be worth insisting that Sky sends you another sim to try to convert which will mean cancelling this one.
Message posted on 25 Sep 2024 01:23 PM
Thank you for your response. The physical sim from my I phone 13 doesn't fit the I iPhone 16.
I have just done what you've said and ordered a new one. Do you know how long it will take? I can't work without being able to receive/make calls or text messages- everything is linked to my phone as a 2-factor authentication 🙈
Message posted on 25 Sep 2024 01:25 PM
Hi @AnnieA77 the physical sim will fit, it should push out to the correct size.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 25 Sep 2024 01:37 PM
Hi John,
it does fit - my apologies.
however it doesn't work anymore as it converted to an eSIM
Message posted on 25 Sep 2024 01:38 PM
Can I reactivate my old physical sim?
Message posted on 25 Sep 2024 01:44 PM
Did you cancel it ?
Message posted on 25 Sep 2024 01:48 PM
No it was changed to an eSIM for the new phone on the sky app.
my old phone (13 with the physical sim) stopped working (texts and calls)
and the eSIM wouldn't work in the new one.
Hence no calls/texts and no way of talking to sky as I don't have a land line
Message posted on 25 Sep 2024 01:52 PM
If it was converted to an eSIM then I don't believe it can be reactivated.
Message posted on 25 Sep 2024 03:12 PM
Hi @AnnieA77 i have escalated your post to sky so look out for a coloured speech bubble on here inviting you to a private chat.
Message posted on 25 Sep 2024 03:23 PM
Thank you
Message posted on 25 Sep 2024 03:27 PM
Thanks for escalating this. We’ve sent @AnnieA77 an invite to chat.
Message posted on 27 Sep 2024 09:12 AM
We are still looking to help you AnnieA77 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
