Discussion topic: Dongle for MacBook Air
This message was authored by: SkiJumper
I have just upgraded my ipad which had the cellular option to a Macbook Air which doesn't.
My question is, can I use the Sky Mobile sim from the ipad in a dongle such as the TP Link M7000 and tether the Macbook off that?
Cheers
Re: Dongle for MacBook Air
@SkiJumper
Apple chooses not to offer cellular data functionality in its laptop hardware.
WiFi from any portable hotspot should work, and any unlocked hotspot hardware should function with a Sky Mobile SIM.
Avatar for SkiJumper
Level 3 icon
Thanks for the reply, I only ask because I was sold an ESim plan with the macbbok, (my own fault for believing the chap at SKY). I phoned to change the esim to a physical sim but the guy said SKY doesnt support their sims in dongles, which I found odd..
I've got a TP Link M7000 on the way so I'll give it a go
