Discussion topic: Do I need to set up a roaming pass?
This message was authored by: Stuart279
Is roamin pass automatically available or do I need to set up
This message was authored by: daveNOS
Re: Do I need to set up a roaming pass?
@Stuart279 It should activate automatically when you connect to a network or send a text, make a call or use any data.
It's worth noting that the roaming passport doesn't cover every country so you may want to look at the tarrifs for the country your visiting, that way you won't run up a huge bill.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
