Discussion topic: Could not receive incoming calls???
Message posted on 24 Sep 2024 09:26 PM
Im so disappointed why I choose sky sim I couldn't receive any calls I tought may be problem in my mobile but mobile is ok problem in network or sim Im not sure but im so upset so many important calls I couldn't receiving!!
Out going call good but couldn't receive any calls!
pls help me as soon as possible
thanks
Message posted on 24 Sep 2024 09:43 PM
Re: Could not receive incoming calls???
Do you know what is happening when someone tries to call you ?
Message posted on 24 Sep 2024 09:45 PM
If someone trying to call me but call ended automatically all my friends saying via watsapp call!
Message posted on 24 Sep 2024 09:49 PM
Are you using Wifi calling, if so what happens if you disable this ?
Message posted on 24 Sep 2024 09:50 PM
No, im not using wifi calling
Message posted on 24 Sep 2024 09:56 PM
I would report this to Sky on 150 to see what they say, at the very least they might send you a replacement sim to try.
Message posted on 24 Sep 2024 09:59 PM
Pls fix this problem as soon as possible otherwise I will stop my direct debit and going through the court!
Message posted on 24 Sep 2024 10:21 PM
How can I fix something when you can clearly see that I don't work for Sky, I have given you advice on what to do and stopping the direct debit isn't what you should do as that will just mean your mobile will be restricted until you pay what is owed.
Message posted on 24 Sep 2024 10:26 PM
Sorry, I thought you are from sky customer services, I really appreciate for your help!
thanks
