Discussion topic: Contact email for Sky Technical re mobile?
Message posted on 15 Oct 2025 11:39 AM
I seem to have found myself in a complete loop with Sky. I recently bought a mobile and SIM which was activated around 10 days ago - all Sky including my home broadband. Since activating, I have had no mobile data so cannot make or receive calls or text - there is no signal and only the satellite icon searching.
My challenge is trying to get this resolved. I have gone through Sky Chat Assist (no help), the online guides and also asked this forum. I have had 3 live chat discussions with customer service agents (as I can't call it has to be chats) and have been told that Sky Technical Support will email me. The agents have said the SIM is fine and it seems to be an issue with broadband or wifi - I told them that I had checked my services (all through Sky) and they are fine and I have no issue with TV streaming or Whatsapp for example. So I'm not even confident that their diagnostic at this stage is correct. I have heard nothing and I'm again back in the loop of being unable to contact the Technical team.
I told the live chat agents that this is my only phone and I live on my own so I do not have access to any other phone. Honestly, I am so frustrated. I just do not know how to access - the contact options all ask for confirmation that you have another phone. Can anyone advise on how I can resolve as I literally have spent hours going around in circles on the Sky site and I'm getting absolutely nowhere. Thanks!
Message posted on 15 Oct 2025 11:42 AM
Re: Contact email for Sky Technical re mobile?
Hi @LindseyB1 there is no email link for Sky departments.
What phone do you have ? Have you checked you have the correct APN settings stored in your phone ? Are you in the UK ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 15 Oct 2025 11:44 AM
Hi John, yes I'm in the UK. I have an Apple 16e. How do I check the APN settings? Not the most technical! Thanks for your speedy response 🙂
Message posted on 15 Oct 2025 11:48 AM
As you have Sky broadband you actually have a Sky Talk landline but choose not to have a handset connected to it.
Even if it's just for instances like this buying a cheap landline handset and plugging it in will mean free calls to Sky from it by dialling 150.
Message posted on 15 Oct 2025 11:50 AM
Thanks Daniel - I did get one but returned it as didn't think I would have any need for a landline. May need to revisit that once/if I can get this resolved 🙂
Message posted on 15 Oct 2025 12:01 PM - last edited: 15 Oct 2025 12:01 PM
@LindseyB1 wrote:Hi John, yes I'm in the UK. I have an Apple 16e. How do I check the APN settings? Not the most technical! Thanks for your speedy response 🙂
@LindseyB1 Go to settings, mobile service, mobile data network and the top APN should be mobile.sky
Message posted on 15 Oct 2025 12:05 PM
John, when I go into Settings/Mobile Service it just comes up with Mobile Data (primary) which is then my SIM. There is nothing that shows network or APN information.
Message posted on 15 Oct 2025 12:08 PM
Are looking in mobile data network @LindseyB1 ?
Message posted on 15 Oct 2025 12:10 PM
This should show after moderation @LindseyB1
Message posted on 15 Oct 2025 12:11 PM
John, when I go into Mobile Data the only things on my screen are:
Off
Primary (my mobile number) - ticked
Travel (the original SIM number before I ported my existing mobile) - turned off
Allow Mobile data switching - turned off
Thanks for trying to help me - much appreciated!
Message posted on 15 Oct 2025 12:12 PM
sorry, John I don't even know what your message means 🙂
I still have no way of connecting with Sky - the Assist bot won't even give me access today despite multiple attempts - just keeps routing me to option which requires me to have another phone
Message posted on 15 Oct 2025 12:13 PM
Not mobile data @LindseyB1 mobile data network
Message posted on 15 Oct 2025 12:14 PM
Your screen shot just came through - that's not what I have on mine - just limited to the 4 I mentioned.
Message posted on 15 Oct 2025 12:19 PM
hi I found it - wrong search! It says my APN is mobile.sky
Message posted on 15 Oct 2025 12:20 PM
but the user name and password fields are blank underneath
