02 Jun 2021 01:06 PM
Thank you!!
03 Aug 2021 11:11 AM
Hi will this work with a Tenda AC1200 ?
06 Nov 2021 10:35 AM
Amazing! Bought Tp-link for our mobile home...struggling to connect.
worked a treat!
Thank you !!!!!
14 Dec 2021 03:54 PM
Hi I have the same issue would really appreciate it if you share how you got it working @Thepreddys
21 Dec 2021 03:16 PM
I have exactly the same problem connecting to Internet with sky sim in a TP Link MR200 router.
What is the TP mini App mentioned above?
16 Apr 2022 11:47 AM
I was pulling my hair out until I found this thread. THANK you so much x
31 Jul 2022 08:04 PM
Just bought the Archer MR 200 could not get it to connect until I found your post. Thank you so much !
21 Apr 2023 09:42 AM
Hi just wondering if I take my SIM card from my phone and put in tpMiFi and put the instructions in to connect to internet will I be able to put back in my phone or am I best getting another sky sim thank you
21 Apr 2023 09:52 AM
Posted by a Superuser, not a Sky employee. Find out moreThere is nothing from stoping you from doing this although it will mean you have no sim in your phone so you will be unable to use it. If you do take out another sim you will be paying for two as you can't have two with the same number.
27 Oct 2023 07:03 AM
I've done this. If you are still struggling with speeds then tray switching the wireless band in the advanced internet setting under the network tab. Looks like sky uses band 1, 8 and 20.
30 Aug 2024 05:14 AM
I'm struggling to connect via sky sim I'm using tp link for 300mbps. 4g lte cheers
01 Oct 2024 10:10 PM
Brian thank you this sorted my issue too very grateful
