1
Discussion topic: Confirming plan for iPhone
This message was authored by ethanccampbell This message was authored by: ethanccampbell
Hi there, I would like to order an iPhone 15 Pro Max 256gb and understand it’s £35 for 36 months. I just wanted to double check some details so I am understanding correctly. After 24 months I am able to upgrade to what I presume will be the iPhone 17 Pro Max or something similar - this is at no extra cost? Also I wanted to check, I currently already have a different SIM only plan with a different network; can I receive the new phone from Sky and still continue to use my old SIM from ID mobile (it is unlocked?). (I can order the 100MB plan from Sky so it is £0 a month, right? And then if I don’t insert the Sky SIM card, after a month it will be removed from my plan?)
This message was authored by caesarome This message was authored by: caesarome Answer
Re: Confirming plan for iPhone
@ethanccampbell
You are correct in what you have said here as you should be able to upgrade after 24 months on the 36 month plan if the condition of the phone at this stage is good as it will be inspected when it has been returned.
You can use any sim in the phone you want so if it will not let you order just the phone without a data plan then order the free 100mb one and don't activate it as it will be cancelled by Sky after 30 days.
@ethanccampbell
