Discussion topic: Changed mobile from EE to sky and now no signal
Message posted on 23 Dec 2024 04:29 PM
I have changed from EE to Sky. Since the changeover, I haven't got any signal at all. My partner is with Sky and has full bars so I know it's not a localised issue with signal. Any help would be greatly appreciated.
Message posted on 23 Dec 2024 04:35 PM
Re: Changed mobile from EE to sky and now no signal
Has Sky told you that the number transfer has been completed ?
Message posted on 23 Dec 2024 04:36 PM
Yes I have had an email to say the changeover has been completed and my EE phone is no longer working. I can use the phone with WiFi however I have no bars at all.
Message posted on 23 Dec 2024 04:48 PM
Have you try sending the network settings to your phone:
Go to sky.com/networksettings (My Account > Mobile > Settings) and sign in with your Sky iD.
Select the mobile number or SIM name you're having trouble with.
Scroll to 'Resend network settings' and select Request settings.
Save the settings when your receive them and reboot your phone.
Message posted on 23 Dec 2024 04:51 PM
I will give that a go now and let you know haha
Message posted on 23 Dec 2024 04:57 PM
I have done that.
when I have gone into my settings and the "about" section, it says not available next to the network section. Maybe I should ring them 🤦🏻♀️
thank you for your help @caesarome
Message posted on 23 Dec 2024 05:08 PM
Is the phone you are using unlocked or could it be locked to EE ?
Message posted on 23 Dec 2024 05:42 PM
I bought a new phone on contract with sky. I applied to change my EE number over to sky which has now been done. Had confirmation email to say that the number has now been changed to the sky phone. I've turned it off and back on, requested network settings, done a new update to IOS18.2. Can't ring from my phone at the moment due to signal issues and wifi calling isn't the best.
I did this with my daughter last week too and hers had no issues whatsoever and found it so easy to transfer. Typical it's my phone that I have issues with 😂
Message posted on 24 Dec 2024 03:35 PM
Have you reset the network settings on the device?
Settings>general>Transfer or reset iPhone>Reset>Reset network settings. You have to set up any WiFi connection after doing this.
I had to do this after transferring from Sky to Smarty.
I don’t work for Sky.
If I have helped then please leave a like.
