Discussion topic: Can I use roaming passport plus when in Morocco?
Message posted on 02 Mar 2025 01:12 PM
I'm traveling alone to Morocco and I'm totally confused by the advise online.
if I purchase a roaming passport plus
- does it cover Morocco?
- is there any other charges that I may occur?
- do I need to change
any settings before I go?
Message posted on 02 Mar 2025 01:17 PM
Re: Can I use roaming passport plus when in Morocco?
The £2 charge doesn't apply in Morocco as it is a "Rest of the world" country so these are the charges:
£2,160 per GB (yes this is correct)
£2.16 per minute Calls to local or UK mobile and landline numbers
£1.80 per minute to receive calls
£0.50 per text message to UK numbers and mobiles
£0.58 per picture message(MMS)
Message posted on 02 Mar 2025 01:18 PM
Morocco is a Rest Of The World destination so it will be very expensive to use your Sky sim there.
Message posted on 02 Mar 2025 01:19 PM - last edited: 02 Mar 2025 01:19 PM
No. Roaming Passport Plus is activated by activity in supported locations only (EU/certain territories)
YES!!!! It's a 'Rest of World' location:
£2,160 per GB (Yes, that's thousands)
£2.16 per minute to make calls
50p per text
Yes, put it in flight mode and use local WiFi unless you have deep pockets.
