Discussion topic: Calls fail whilst abroad
This message was authored by MattG0123 This message was authored by: MattG0123
Both myself and my wife have sky mobile, we are currently abroad and neither of us can make calls. It always comes up call failed. Been abroad for around 4 months, was working fine until the past month. Both of us have the same issue.
Tried adjusting all settings on the phone, plus the sky mobile app, nothing works
Re: Calls fail whilst abroad
Have you both got spend caps set for your devices as you will need this setup if you haven't.
MattG0123
Yes we do. I've already tried removing them and it didn't make a difference.
This message was authored by 63johnw This message was authored by: 63johnw
Hi @MattG0123  there was a rule introduced when we were part of the EU that you had to connect to your home network every few months or your phone would stop working, this was to prevent people getting cheap deals in one country then moving to another. Not sure if this is still the case now we have left the EU though.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
MattG0123
Ok thanks for the info. Any idea how to reset that?
Not even sure if it's still a thing @MattG0123  and the only there was to reset it was to login to your home network in the UK.
