12 Aug 2022 05:44 PM
Am going to new york city and need to know what i need do to keep the cost down for my phone?
12 Aug 2022 06:01 PM - last edited: 12 Aug 2022 06:02 PM
Posted by a Superuser, not a Sky employee. Find out moreDepends on what you want to do.
if you want to use calls/data then it will be £2 per 24 hours (was reduced from £6 recently).
if you want to save even more then turn off mobile data and roaming and use any public Wi-Fi you can. (Send messages or make calls via WhatsApp or similar)
12 Aug 2022 07:26 PM
Posted by a Superuser, not a Sky employee. Find out moreDepends on how long you are going to be there because if it is a few months then it would be worth you purchasing a sim while you are out there and using it in your device if it is unlocked which if it was from Sky will be.
