2 meg data speed honestly
This topic has been answered
Go to Answer
Managing Editor
Post 1 of 15
Is 2 meg down and upload speeds the best sky can achieve via mobiles
Any plans to bring it up to the  previous o2 speeds of almost 20 meg/s
Answer
Answer
Camera Assistant
Post 6 of 15
Re: 2 meg data speed honestly
@Donfor wrote:
No luck 2meg from various locations since Airplane enabled:disabled
maybe need a call to sky mobile
Try a reboot then, they will ask you to try this anyway so you may as well get it over with before wasting time in a queue.
First Assistant Director
Post 2 of 15
I get around 17 Mbps down and 14 Mbps up at home which is about the same as I was getting when I was on O2.
_____________________________________________________
Sky Q 2TB v2 + 2x Mini, LG 55UH850V, Lumagen Radiance Pro 4242,
Yamaha RX-A2040 (7.1.2) + Yamaha A-S1100
Camera Assistant
Post 3 of 15
Try putting it into airplane mode and then back out again.
https://helpforum.sky.com/t5/Sky-Mobile/Extremely-slow-non-existent-Data-speeds/td-p/2839427
Managing Editor
Post 4 of 15
I shall try that thanks @Colin0000
Managing Editor
Post 5 of 15
Answer
Camera Assistant
Post 6 of 15
Managing Editor
Post 7 of 15
Re boot since got almost 20 meg down
Upload shoots to almost 30 meg then Sharp drop to 2-5meg.
Seems a bit better though certainly not the o2 stable 20up/10down-not that I upload anything and not much downloads from Xs.
Managing Editor
Post 8 of 15
42 meg d/load
30 meg u/load
This morning from Xs 4g data
Is this luck or does it suggest 63mb fibre upgrade has been applied,.
Camera Assistant
Post 9 of 15
@Donfor wrote:
42 meg d/load
30 meg u/load
This is a very confusing post, are you testing over 4G or (as I expect) over your broadband?
Managing Editor
Post 10 of 15
Yeah it prob isn't valid question as the speed increase is from sky mobile iphoneXs
maybe I'm next to a mobile transmitter today.
I'll delete next post with screen shot.
Oracle
Post 11 of 15
@Donfor
Sky Mobile just piggybacks O2 so you'll get similar to speeds to whatever O2 gets. The speeds can vary day by day and hour by hour depending on location.
Managing Editor
Post 12 of 15
Not necessarily @jamesn123
Until recently I was getting 2 meg.
Today over 40 up 30 down.
Not at Home though maybe I'm closer to a mobile  transmitter or mast.
Granted my enthusiasm incorrectly thought the 63 meg offer had been applied which of course is unrelated.
Oracle
Post 13 of 15
@Donfor It completely depends on your location, time and current population of the area. E.g. At peak times during the day my 4G speeds can drop below 5Mbps but If i go 1mile down the road later on in the day the speeds come up well above 50Mbps. Thats just mobile networks for you unfortunately
Managing Editor
Post 14 of 15
Since returned home.
30 meg up 10 down.
The recently suggested reset from another forum user has indeed sorted my mobile data speeds
Oracle
Post 15 of 15
Glad you are sorted, the good old reboot usually never fails !
Recommended Threads
11 minutes ago 05:22 PM
13 minutes ago 05:20 PM
DanCon123 26 minutes ago 05:07 PM
Anonymous 4 hours ago 01:20 PM
