Discussion topic: "we're having problems connecting your application, please try again (001)".
This message was authored by: lilsam09
I had this error message for 4 months now "we're having problems connecting your application, please try again (001)". Yet they us no fix and your still charging
Re: "we're having problems connecting your application, please try again (001)".
Are you using a VPN because if so it will need disabling, if you are not then make sure that Sky Go is let through any firewall you use.
Avatar for lilsam09
Done all recommended fixes and still not working
If you disabled your VPN then I would try rebooting your PC.
Avatar for lilsam09
Still got the same error
This message was authored by: Csh2
Tried everything until disabled VPN, that worked
