Discussion topic: help sk go app wont load on iintel imac running osx 12.7.6
This message was authored by: hi+zeffy
Can someone please help me resolve this problem? thanks
Translated Report (Full Report Below)
Process: Sky Go [77119]
Path: /Users/USER/*/Sky Go.app/Contents/MacOS/Sky Go
Identifier: com.bskyb.skygoplayer
Version: 24.2.3 (24.2.3)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025
OS Version: macOS 12.7.6 (21H1320)
Report Version: 12
Anonymous UUID: B53F7A5C-671A-1458-E843-F6B8DF8E9AA5
Sleep/Wake UUID: 532DB4E5-F772-4A13-9CE9-8A78073AFC26
System Integrity Protection: enabled
Crashed Thread: 20 ThreadPoolSingleThreadSharedForeground1
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000001170c6177
Exception Codes: 0x0000000000000002, 0x00000001170c6177
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process: exc handler [77119]
Re: help sk go app wont load on iintel imac running osx 12.7.6
Edit: removed
Avatar for hi+zeffy
I'm sorry. I meant to write that the Sky Go app keeps crashing. It briefly shows the page to enter username and password but then crashes immediately. I removed the app from my applications folder, binned it, and downloaded it again from the sky.com website, but it still won't load.
I'm on an intel IMAC, 5k retina running OSX Sonoma,
4 GHz Quad-Core Intel Core i
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4 GB
Ive checked the spec which is good for Sky Go app.
thanks
