Discussion topic: Sky go will not work via home wifi
Message posted on 17 Jan 2025 02:29 PM
Sky go app only works via mobile data at home, and only 1 person at a time can watch it, yey it works fine at work using their Internet.
- Un installed, re installed, updated, rebooted etc, nothings working. Have been on with a tech for over an hour, and he is stumped. It's all channels, not just sports.
Message posted on 17 Jan 2025 04:09 PM - last edited: 17 Jan 2025 04:13 PM
Re: Sky go will not work via home wifi
Are you meaning trying to use with Sky Q at home?
If not, do you get any errors in the Sky Go app, when you launch it under your wifi?
If so, do you have the Sky Q Multiscreen package?
You’ll need a Sky Q Multiscreen subscription to watch live TV when Sky Go is connected to your Sky Q box, and also watch and download recordings from your Sky Q box to the Sky Go app (if you have Sky Q Multiscreen, you’ll already have Sky Go Extra).
Please note: You won’t be able to access recordings from your Sky Q box if you don’t have Sky Q Multiscreen.
Have a read of this Sky help article
https://www.sky.com/help/articles/sky-go-with-sky-q
Message posted on 17 Jan 2025 04:25 PM - last edited: 17 Jan 2025 04:25 PM
Plus, may be worth a reboot try of your home broadband router, then reboot your devices you use for Sky Go.
Message posted on 20 Jan 2025 08:36 PM
I have got this in recent days as well. First reboot sorted it but now I am trying every day and it fails. Reset everything and removed and reinstalled all apps twice and nothing! Disconnecting the wifi works but it frezzes not long after I reconnect!
Message posted on 20 Jan 2025 10:08 PM
I have the same issue, with Sky Go. It works fine with a mobile signal and at work over that WiFi, but doesn't work over Sky Full Fibre Broadband at home. Tried resetting the router, Sky Q box, uninstalled and reinstalled the Sky Go app and still Sky Go will not work. Can anyone at Sky offer a solution please?
