Discussion topic: Sky go on tablet says external display output is blocked , but tv plays on phone
Message posted on 19 May 2025 08:32 PM
How do I play sky go on tablet keep saying external display output is blocked
Message posted on 19 May 2025 08:33 PM
Re: Sky go on tablet says external display output is blocked , but tv plays on phone
Do you have it connected to something, if so you will need to disable it.
Message posted on 19 May 2025 08:41 PM
I've also restarted and uninstalled app but still not working
Message posted on 19 May 2025 08:43 PM
What do you mean connected elsewhere like console or app on phone
Message posted on 19 May 2025 08:54 PM
I have disconnected all devices but still saying the same
Message posted on 19 May 2025 10:15 PM
After disconnecting anything it was connected to have you then rebooted your tablet ?
Message posted on 23 May 2025 03:52 PM
Thanks everyone I found out what it was my tablet did an update and connected me to some thing called dex, I then switched off smart view mirror screen now I can play sky go on tablet
Message posted on 29 May 2025 07:13 PM
Hi all
So just wanted to share that if you have a Samsung tablet giving this error, it is most likely because Dex is switched on. I uninstalled Sky Go and rebooted multiple times without success, this response was the one that sorted it for me.
Thanks.
