24 Dec 2023 12:28 PM
My SkyGo app on my iPad regularly appears to lose connectivity with the SkyQ box, so that I get a message 'Sky Q box not found'. I can reconnect by rebooting my router and restarting the Sky Q box, but the next time I try to use the SkyGo app the connection has gone again.
The odd thing is that when I look at the SkyGo settings, the app still sees my 2 Sky Mini boxes, just not the main Sky Q box.
Does anyone have any ideas?
22 Jan 2024 04:29 PM
just wondering if you got this problem sorted? as i have the very same since i re contracted with sky .
Sky Go would work not all of the time but it would connect about 60% of the time, but now it wont connect at all, just the message Sky box not found
regards
22 Jan 2024 04:36 PM
No, not sorted, I'm afraid. The engineers who came out to fix the mini-box problem last week replaced the faulty SkyQ box, which they said would also solve this probelm, but it hasn't.
22 Jan 2024 05:33 PM
Thanks for that,that Sky Go app never worked right it's been hit and miss with me ,and I'd say we are not the only ones regards
22 Jan 2024 05:35 PM
Good luck. Oddly enough I can still record from the SkyGo app, but I just can't see my recordings. Life's just too short to keep chasing this one!
13 Feb 2024 06:31 PM
I too had my skybox (the mini box not the main Q box) replaced today and for a very brief while the sky go worked, by which I mean it could connect to the sky Q box As soon as the engineer went it stopped being able to connect again.
The fault applies on my iPhone, my iPad, and my wife's iPad.
I've tried telephone support the virtual non-assistant and emailing without success.
Obviously I've done the power of the devices off reload the app Power the Q off, power booster off, power router off many times over several weeks without sucess.
There must be a clue in the fact it worked while the engineer from Sky was here and had Sky go on his iPad connected to my broadband network. Any ideas please
29 Feb 2024 04:09 PM
Hi - Did anyone get this resolved? My in laws have a Sky Q box with multi screen subscription. They have the Sky Go app (latest) installed on their Samsung tablet. They cannot accwss recordings on the Sky Q box, not watch BBC 1/2 using Sky Go on their tablet as it continuously says they are not connected to their Q box.
Following the procedure on Sky website (restarting router and Q box) briefly gets it all talking. Within ,5-10 mins it is no longer connected.....
They are not behind a VPN or anything on their tablets....
29 Feb 2024 04:36 PM
Lots of people with the same problem, no solutions, typical of Sky.
29 Feb 2024 06:00 PM
@regency71 ,no not resolved, just going around in circles, tried everything that sky suggested several times, even the sky technicians couldn't get it working,and they have a cheek to email me to say my subscription is going up, a law on to themselves
Regards Frankie
29 Feb 2024 09:35 PM
Having just moved house, I have a Sky engineer coming here early next week to set up Sky Q again. I'll ask the question ...
29 Feb 2024 09:54 PM
@scrambler60 since I renewed my contract in December it hasn't worked,I changed nothing on my package,I have multi room but nothing I do gets it to connect
I'll be interested to hear what he says ,thanks
07 Apr 2024 11:55 AM
This is what fixed this issue for me.
Sky Go on my iPad Pro was always hit and miss at connecting to my Sky Q box, but recently it's been much worse. Up until this morning, none of my Sky Go clients (iPad or PC) would connect to the Sky Q box.
I've been a Network Engineer/Architect for 30 years, so I decided to get to the bottom of this once and for all. I did an IP packet trace from my PC with the SKy Go app running. I hit the 'find Sky Q Box' a few times and looked at the capture.
The app sends an SSDP 'Search' on the multicast address 239.255.255.250:1900 and the Sky Q box should respond to this packet. However, other upnp devices on the network also listen on this port and are quicker at responding. In my case, my wife's Amazon Firestick was the culprit. I could see on the packet trace that it was responding to my Sky Go client and this was causing it to fail in finding the SKy Q box. I turned the Firestick off and now all of my iPad and PC see the Q box and I can watch recordings.
I turned the Firestick back on and so far, the clients are still working ok.
Hope this helps someone else with this problem.
Andy
07 Apr 2024 12:39 PM
Interesting. For my part, as th eoroiginal poster, the problem seems to have gone away. We moved house, and our internet provider gave us a new FritzBox router to replace our old ASUS one which was not compatible with our new service. Why this should have resolved the problem I have no idea, but it has!
25 Apr 2024 01:31 PM
The Sky Q box and the device must both be connected to the same network for this to happen successfully, so if you have any wifi boosters in the property, one of the devices may be connecting through that and it is showing a different SSID, try temporarily turning off the booster and ensure both devices are conencted to the hub and hopefully this should allow the connection to be made between the device with Sky Go and the Q box.
08 May 2024 10:48 PM
I've just had this problem resolved after going through every setting and all the turning off and on again with previous advisors.
Turns out when I ordered multiroom it knocked off my sky go extra (that allowed me to use this recordings function free as VIP member)
The advisor needs to get my sky viewing card updated to include this again . In short it was my account rather than my equipment . So simple but only this one guy at sky cracked it
On average, new discussions are replied to by our users within 3.6 hours
