Discussion topic: Sky go App technical issue
This message was authored by Rish18 This message was authored by: Rish18
Hi,
I am trying to log in to Sky Go app and each time I get a notification stating "Sorry, something went wrong. Because of a technical issue, you cannot watch this channel. Please try again later". I am using an iPhone 11.
Went through other forums as well but have not found a solution that works for me. Can someone help?
Re: Sky go App technical issue
Does your password contain a symbol, if so you could try changing it to one that just contains letters/numbers:
https://skyid.sky.com/resetpassword/
Rish18
Hi Caesarome. Changed password now. Still doesn't work.
Is your iphone running the latest IOS software ?
Rish18
Yes, I have iOS 16.0 which seems to be the latest update
This message was authored by Mlau0774 This message was authored by: Mlau0774
Hi have you resolved this issue?
mine says the same . Thanks
On average, new discussions are replied to by our users within 3.6 hours
