Discussion topic: Sky Go will not install on MacBook Air M2, running 14.5
Message posted on 18 May 2024 09:19 PM
Hi,
I have read through various threads but none of the solutions are working for me,
I have a 2023 MacBook Air M2 running Sonoma 14.5,
I am trying to download and install SkyGo however I cannot get it to install no matter what I try..
The file will download correctly, and then when I try to install it, it does nothing (see image below)
Once the blue bar gets to the end nothing else happens.
I have Rosetta installed which has made no difference.
I have tried everything with no luck, and I really need this app!!
Message posted on 16 Jan 2025 06:23 PM
Re: Sky Go will not install on MacBook Air M2, running 14.5
I have the same issue. After an apparet good installation, nothing appens and the app doesn't starts.
This is my configuration:
