25
Discussion topic: Sky Go stuck in looking for updates. doesnt load.
This message was authored by Icebear1994 This message was authored by: Icebear1994
I tried to delete and re install, tried closing computer,  please help. doesnt seem to load.
This message was authored by Dave+Lorde This message was authored by: Dave+Lorde Answer
Re: Sky Go stuck in looking for updates. doesnt load.
I've had this problem for months on a new Windows 11 PC - I tried uninstalling, rebooting, & reinstalling a number of times with no joy.
Finally, I used Revo Uninstaller to uninstall & remove registry & system entries for it, then followed the instructions here to delete the SKY folders that Revo didn't find; then rebooted and reinstalled from a fresh download, and it worked!
So far, so good...
This message was authored by NicolaAndJohn This message was authored by: NicolaAndJohn
I'm having the same issue on a windows 10 laptop checking for updates and then it crashes
Try this:
Uninstall the Sky Go app and then go to 'C:\Users\[your user name]\AppData\Roaming (ensure hidden files/folders are visible) and delete the following folders:
Sky
Sky Go
And if it is present the Cisco and/or Synamedia folder in App\Data\LocalLow.
Empty your recycle bin.
Reboot your PC and then download and install the Sky Go app again.
nope didn't work tried it twice now
This message was authored by Stewooc This message was authored by: Stewooc
I am having the same problem with my Skygo app on my surface pro.
This message was authored by Whatt This message was authored by: Whatt
Me too.. tried the above many times. Sometimes sticks once, sometimes many times. Most annoying!
This message was authored by Liz1999 This message was authored by: Liz1999
I have the same problem but it works if I disable Nord VPN, seems to block it from contacting the server to update
This message was authored by Sturmillar This message was authored by: Sturmillar
The issue is becasue its blocked by either the Windows, or 3rd party firewall.  If able, try temporarirly disabling it.
This message was authored by Lucifers+Consigli This message was authored by: Lucifers+Consigli
Come on Sky, get a grip! This issue has been plagueing users for ages
This message was authored by fisbo This message was authored by: fisbo
I got this issue after updating to Windows 11 last week.  What works for me is:
Go to C:\Users\yourusername\AppData\Roaming and delete the Sky Go folder.
Then click on the Sky Go app, it opens, goes straight to downloading an update and opens as normal.
I have to do this everytime I open the app though.
This message was authored by AndyH This message was authored by: AndyH
Hi All,
Good grief, I thought this whole issue had been fixed long ago but on  loading up a new Ryzen Win 11 Mini-PC and trying with  Sky Go, here we are again.. stuck on updating all the time.
First time I simply uninstalled Sky Go and re-installed it.. no deleting data directories or anything.. and that worked. The next time I use it it's back waiting on checking updates again. I've opened up the Firewall for the app, paused the Virus scanner and all the usuals but is seems to have some other reason for intermittently failing.
Last time I played around with this in earnest must be two or three years ago, I can't believe it's still an unresolved issue!
This message was authored by lwithers This message was authored by: lwithers
I have been having the same problem. On my Windows PC, I usually press ctrl + alt + delete and open up my task manager. If the app is glitching, I have 'ended task' and opened it again which seems to work. Although, I have to do this nearly every time, it is quicker than deleting and re-downloading the app.
This message was authored by Gaylereeves This message was authored by: Gaylereeves
I'm at the end of my tether with this! I've tried all the methods on this forum all to no avail, come on Sky you can't provide a program/app that's not fit for purpose. I use Sky Go on my Windows 10 Laptop and I got a message saying the app was corrupt and I had reinstall which I did and it's been all downhill from there. Please Sky find a solution and not just a rehash of the advice already provided, because I've tried all the solutions on offer to no avail.
Cheers
This message was authored by Purple+Heron This message was authored by: Purple+Heron
Exactly the same thing is happeing to me and many others by the looks of things. Can't beleive it's not fixed or that there is no work around that works posted on line. Very irritating!
This message was authored by Fremsley This message was authored by: Fremsley
I've had this problem for years. Reported it to Sky several times. Still not resolved eh?
Sky are a multinational media company, charging top dollar for their services (and often overcharging 'by accident').  What does that tell us?
On average, new discussions are replied to by our users within 3.6 hours
