This discussion topic has been answered Discussion topic: Sky Go since moving from Sky Q to Sky Stream
Message posted on 29 Dec 2024 07:31 PM
I used Sky Go when I had Sky Q. Since moving to sky stream I have noticed the app still shows details that refer to Sky Q box, for example Q Recording on the bottom right of the app. Should the app change when moving to Sky Stream?
Message posted on 30 Dec 2024 07:46 PM
@JasonHayes wrote:
Did someone at Sky press a button?
It is more likely that as a new customer the system has now caught up to reflect this.
Message posted on 29 Dec 2024 07:51 PM - last edited: 29 Dec 2024 07:52 PM
Re: Sky Go since moving from Sky Q to Sky Stream
No I used to have Q when I moved to Steam, Sky Go recordings disappeared, try logging out & in again it'll just say downloads where recordings were
Message posted on 30 Dec 2024 06:57 AM
Hi. I'm still doing Sky Recording and Downlaods at the bottom of the Sky Go app. Of course these features are no Avila le since moving to Sky Stream. Does the Sky Go app change after moving to Sky Stream?
Message posted on 30 Dec 2024 09:43 AM
When you moved to Stream, did you continue with the same account or were you given a new account number ?
Message posted on 30 Dec 2024 05:20 PM
Hi
the same account number.
Message posted on 30 Dec 2024 07:33 PM
My Sky Go app has just changed. The bottom bar has now changed and Sky Q has been removed. This now more reflects by Sky Stream subscription which was activated on Saturday morning some 48+ hours ago. Did someone at Sky press a button?
