Discussion topic: Sky Go not working on iphone 14 pro through wifi but work through 3g and work at home
This message was authored by: Lightbros
I have tried all suggestions, turn on and off, remove app etc and it still shows error messages and will not play but work fine using data and on my wifi outside in the garden at home? Getting very frustrated
Re: Sky Go not working on iphone 14 pro through wifi but work through 3g and work at home
What is the error message and is it indoors at home via Wifi that it isn't working ?
Avatar for Lightbros
Hi, it's at work and came up first with error 50-2 so tried all suggested for this, then came up with device not authorised so tried all suggestions with this, then it goes back to error 50-2 ? However it work fine with Wi-Fi switched off and works fine at home on the Wi-Fi 🥲
If it is working on your home Wifi then it suggests your works Wifi is blocking it so perhaps speak to your IT people ?
