Discussion topic: Sky Go Unable to connect to SKY Q box
Message posted on 21 Jun 2024 08:59 AM
In need of help for my first post as Sky helpdesk werent able to help.
I have Sky Q with multi room subscription and when I log on to Sky Go on my laptop there is no recordings option in the menu so I am unable to see my recordings and connect to my Sky Q box.
I am able to use Sky Go to watch live TV but nothing else. I have had the laptop next to main box and have reactivated the sky go on the main box and I have tried to reinstall sky go to an older version but the first thing it does it upgrade to the latest version of the app. I have also turned off and back on the setting in sky go to connect to sky q.
I am using app version 24.1.3-2
When i contacted sky they said it must be an issue with my laptop but couldnt give me any further help. My laptop is connected to same network as my Sky boxes and they can see the internet so am at a loss how to get access to my recordings using sky go.
Any help is appreciated.
Message posted on 21 Jun 2024 10:15 AM
							Re: Sky Go Unable to connect to SKY Q box
Have you tried rebooting everything, so your laptop and Sky Q box and your broadband router ?
Message posted on 21 Jun 2024 10:18 AM
thanks for response.
Yes have rebooted everything multiple times but still no joy.
Message posted on 21 Jun 2024 01:11 PM - last edited: 21 Jun 2024 01:11 PM
Is that a network generated by an ISP router, an non-ISP router or a mesh system?
Some hardware will have wireless client isolation switched on by default, which can cause this issue.
Message posted on 21 Jun 2024 01:24 PM
Its an ISP router and is actually Sky that provide our router and internet.
Message posted on 21 Jun 2024 01:42 PM
OK, that doesn't do isolation.
Does the laptop have any VPN functionality?
Message posted on 21 Jun 2024 02:10 PM
It does have VPN capability but there is no VPN installed on the laptop.
Message posted on 25 Jun 2024 09:00 PM
@MartynC10 hi I have the same problem. I've used sky go for a couple of years on my kindle fire 10 with no problems but in the last few months I cannot access my recordings saying it cannot find my q box. I've switched box & kindle off then turned on again no joy. I then uninstalled the sky go app & then reinstalled & now I don't have the recording option at all, it has disappeared. All other options are there, so now I can't retrieve my recordings ordings. Very annoying
Message posted on 15 Feb 2025 12:56 PM
I'm having the same issue, and bizarrely while my  wife's iPad will connect to the Sky Q box, mine won't.
I've rebooted the router, box and iPad, removed and reinstalled the SkyGo app, and made sure the App,e Private Relay is off.
No joy.
Any suggestions gratefully received.
Message posted on 15 Feb 2025 03:00 PM
I am in hospital and wish to connect via their WiFi which has a strong signal
Message posted on 15 Feb 2025 03:13 PM
It randomly started working so assume code update but no clue why is started working.
Message posted on 22 Sep 2025 11:02 AM
I need an engineer. We have had a problem for two days
Message posted on 22 Sep 2025 01:33 PM
What problem are you having ?
