Discussion topic: Sky Go, Sky Q recordings and PIN
This message was authored by: AnytimePlus+On+VM
So, I've disabled the PIN (as much as you can do) on our Sky Q boxes.
This works as expected, you get asked for the PIN now and again.
So lets pick something like a recording of Blue Bloods.  I don't get asked for the PIN when watching this on our Sky Q boxes.
If however I try to watch this via Sky Go (on the laptop in the study) via the recordings options.  So watching the recording on the Sky Q box, not downloading on demand.  I am asked for a PIN.
Is there a reason for this?  Have I missed a Sky Go setting somewhere.
It's not the end of the world, just wondered why the difference.
Re: Sky Go, Sky Q recordings and PIN
@AnytimePlus+On+VM
If the Sky Go app is not connected to a Sky Q box then the pin for it can be reset here:
https://www.sky.com/manage/tv/manage-devices/change-pin
Setting parental control level:
https://www.sky.com/myaccount/tv/manage-devices
Avatar for AnytimePlus+On+VM
Level 6 icon
I don't want to change the PIN and I believe I've set all the parent controls.
I just wondered why there was a difference between watching the recording directly on the Sky Q box (doesn't require a PIN) compared to watching the recording from the Sky Q box on Sky Go (does require a PIN).
