Discussion topic: SKY Go : Can you authorise a connection?
This message was authored by: BC
can you authorise or bar an attempted SKY Go connection.
Some random device keeps appearing on my list of known devices?
Anytime know how to stop this?
Re: SKY Go : Can you authorise a connection?
Try this:
First change your password:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off, this might not stop them straight away but it will over a day or so.
Avatar for BC
Thanks for that advice
I have tried it before)
(Or I thought I had at least)
Re-tried just now
I'll see what happens when my kids at Uni, start to complain...
Then I'll know it's worked this time
I'll re-post here if it works
and say thanks
and also if it doesn't work,
and if there are any other suggestions
