Discussion topic: SKY GO NOT WORKING SENOMA 14.5
This message was authored by: Spindragon
SKY GO wont open, deleted all files, restarted mac. downloaded a fresh file from sky web site, opened the installer.
The installer finishes and nothing the app won't open, trys to open when clicked bounces up and down in the dock for a second or two then vanishes without opening.
Tried 5 or 6 times no change.
Switched into bootcamp windows similar issues sky go won't open, it downaloaded and installed an update when i first tried to open it on the 18th april 2025. the update installed fine however when i open the app it just has an error message. So once again i am back unable to use Sky Go...
Not etirley sure why but this has happened twice in the last few months all was good it was working on both mac and windows and now nothing, the app needs a bloody big upgrade to fix all the bugs. Before i get some pointless reply yes i have a subscription to use sky go as mentioned it was working fine and it is working on my android but screen is a little small hence the laptop/mac usage.
This message was authored by: Greenfingers001
Re: SKY GO NOT WORKING SENOMA 14.5
