Discussion topic: Recording and catch tv not working
This message was authored by Peugeot26022012 This message was authored by: Peugeot26022012
Am unable to see my recordings ot access catch up tv, also both my mini box have no signal
Re: Recording and catch tv not working
Looks like you may have a hard drive issue @Peugeot26022012
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
