Discussion topic: Ordered Sky TV - Can't use Sky Go
This message was authored by: Daveo16
Ordered Sky TV (Sky Q) within the last hour and when I login to Sky Go says Technical Error.
I have a Sky ID, as that's used for my Sky Mobile, but it doesn't show that I've ordered Sky TV. Only shows my Sky Mobile account.
Re: Ordered Sky TV - Can't use Sky Go
@Daveo16
You might need to link your account to your Sky ID as per this:
https://www.sky.com/help/articles/sky-id-cant-access-all-my-services
Avatar for Daveo16
That don't work for me.
Says can't complete order.
I ordered Sky TV when I wasn't logged in to my account, but I used the same email address that is linked to my Sky ID account (which has my Sky Mobile account linked).
That doesn't always mean it was ordered on the same account so to get you some help with this I have escalated your post to the Sky Messaging team who should be in touch with you regarding this via a blue/red chat bubble which will appear at the bottom of this page. It can take up to a few hours to be contacted via this.
This isn't a live chat so replies may not be instant.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Daveo16.
Avatar for Daveo16
@Addie15  got your PM but I'm unable to reply as it says PM not enabled.
Not sure if that's not enabled for me or you.
@Daveo16
You need to respond to the chat bubble and not the message telling you that you have been contacted so as stated earlier you should see the chat bubble at the bottom of this page somewhere.
Avatar for Daveo16
Ty. Found it in the end.
Avatar for Daveo16
Finished using the Sky help chat thing, but can't get rid of red/blue chat icon at bottom if forum.
Any ideas?
Could they not help, what did they say to you ?
Avatar for Daveo16
They couldn't add the TV to my existing Sky ID, so had to create a second Sky ID for the TV, which they are unable to merge the two Sky IDs either.
Not the best setup, but I can manage them with mySky on iPhone for the mobile & mySky on iPad for TV. Sky Go is also on iPad.
Just got to wait for install & activation then I may be able to link them via the Add User feature, so that it doesn't then matter which Sky ID I login with, I should be able to access Sky Go with either Sky ID then.
