This discussion topic has been answered Discussion topic: My Sky Go works once, then stops
Message posted on 31 Oct 2023 08:53 AM
I have an Amazon Fire HD8 I can install Sky Go and use it without any problems. I close the session and when I re-start Sky Go launches, but when I try and watch say Live Cricket it fails saying there is a technical issue and to try again later. I then unistall the app, download it again and install it and it works first time.
Please can you advise why this is happening and the solution to ensure the app works each time its launched and not require me to unistall/re-install every time I use it.
Many thanks
Kevin
Message posted on 31 Oct 2023 09:48 AM
Try signing out of the app then reboot your device and the sign back into the app.
Try linking your Sky ID to your account, help on doing this can be found here:
https://www.sky.com/help/articles/sky-id-cant-access-all-my-services
Message posted on 01 Nov 2023 09:09 AM
Re: My Sky Go works once, then stops
Many thanks, seesm to be signing out issue. I have successfully restarted and the App now work.
Kevin
