22 Dec 2024 05:52 PM
For the Last week have been unable to watch football games on my iPad.
tells me to download app, ido again and just go,round in circles.
22 Dec 2024 07:39 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you are a Sky Tv customer with the sports packge on your account then you can use either the Sky Sports app or the Sky Go one so have you tried both of these ?
22 Dec 2024 10:08 PM
Hi
thanks for reply, have tried going through my sky sports app as usual but it doesn't load and tells me to download the app again, which I've done, with no luck.
22 Dec 2024 10:30 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat OS is your iPad running ?
This can be found via General > About > version.
22 Dec 2024 11:18 PM
Version 18.1.1
downloaded recently
23 Dec 2024 05:38 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried installing the Sky Go app instead ?
23 Dec 2024 12:33 PM
Thanks for your help, it is working on Sky go.
Strange it stopped on sky sports.
03 Mar 2025 07:41 PM
I was told it was an issue between sky and apple. I'm trying to find out if it's fixed as I want to watch the golf! Such a pain
03 Mar 2025 07:52 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat is the issue as you haven't said what is happening ?
03 Mar 2025 08:50 PM
It tells you that you can't view, Sky Techs know about it but can't get an answer to say when it'll be fixed
14 Mar 2025 10:29 PM
Having the same issue? Asked to down load the Sky Sports app, which then tells you to download a file Mac/PC when done the file say open but it actually wants you to save it?
14 Mar 2025 10:33 PM
Posted by a Superuser, not a Sky employee. Find out moreHave you installed it via that small link, if you have select the channel you want to view here then it should load up:
https://www.skysports.com/watch
14 Mar 2025 10:37 PM
That small link provides a File that says OPEN but only wants to download which will not open after the download?
15 Mar 2025 05:40 AM
Posted by a Superuser, not a Sky employee. Find out moreThe desktop player can only be installed on a PC/<ac so what device are you trying to install it on as it looks like an Apple device then if so I don't believe you can get it installed on this.
If you can't access Sky Go then there is the Sky Sports app that might work for you.
15 Mar 2025 06:23 AM
I've got it working now, thanks
On average, new discussions are replied to by our users within 3.6 hours
