Discussion topic: I can’t log in to sky go on a PlayStation 5
This message was authored by: LisaG100819
I use to be able to log into sky go on my PlayStation 5 and now it says I can't
Re: I can’t log in to sky go on a PlayStation 5
Can you proved the exact message you are getting?
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
This message was authored by: Amorgan90
@Annie+UK i am having the same issue too. I have 2 devices registered and I have sky go extra which allows consoles, but my PlayStation 5 says 'you can't use sky go on this device yet. You'll need a multi screen, sky glass whole home or sky go extra subscription to access sky go on this device.
as I have sky go extra I would expect this to work and in the past it has done. Any ideas?
Call Sky and have your account checked
Use the following link for contacting Sky: CONTACT
A phone number is given on a link on the page linked to below (click on the "Need more help?" drop down):
There is also Sky's How can we help? page
(make sure the correct country is selected at the bottom of the page)
